Hi to all, i starting to use Paraview few days ago and i’m not so expert so sorry if the question is trivial.
I obtain this 3d mesh from FreeFem++ and i want to take a slice of my domain, visualizing the tetrahedra and not the triangle. But all the filters are blocked and says “requires an input”.
What can i do to solve this problem? Am i do some error in save the .vtk file?
thank you! Now filters is available. But i believe that in my mesh there was some tetrahedra (MMG3d says that i have about 900k in this mesh) but if i try to view with “volume” appear the error message “Encountered non-tetrahedra cell!”
I have to set some other options to visualize these elements?
unfortunatly also with flux fast and solidcolor obtain the same error. It’s vey strange, i’m sure i compute tetrahedra on Freeefem++. Maybe there is some option to add in the command “savevtk”?
Anyway, i can’t add tetraedra on this mesh by paraview?
The tetrahedra are already present in your file. Volume representation is meant mainly for images. Try setting the representation to Surface / Surface With Edges / Wireframe which is better suited for meshes.
