When using pvbatch with multiple GPUs, nvidia-smi reports that only GPU0 is being used. To ease reproducing this on Kitware’s side, here are some steps and scripts that we used:
- I handcrafted a simple python script called
test.py.
from paraview import simple
renderViewSettings = simple.GetSettingsProxy('RenderViewSettings')
# Properties modified on renderViewSettings
renderViewSettings.RemoteRenderThreshold = 0.0
a = simple.Cone()
simple.Show(a)
simple.Render()
simple.SaveScreenshot("/tmp/hello.png")
import time
time.sleep(20)
- Now, I created a headless EGL
pvserverusing
mpiexec \
-np 2 -x NVIDIA_VISIBLE_DEVICES=0,1,2,3 ./pvserver --mpi --force-offscreen-rendering --displays 0 : \
-np 2 -x NVIDIA_VISIBLE_DEVICES=0,1,2,3 ./pvserver --mpi --force-offscreen-rendering --displays 1 : \
-np 2 -x NVIDIA_VISIBLE_DEVICES=0,1,2,3 ./pvserver --mpi --force-offscreen-rendering --displays 2
- I then connected to this
pvserverusing a QTparaviewbinary, rantest.py, and saw 3 GPUs being used innvidia-smi. Hence,pvserverseems to be working fine. - I tried then with
pvbatchusing
mpiexec \
-np 2 -x NVIDIA_VISIBLE_DEVICES=0,1,2,3 ./pvbatch --mpi --force-offscreen-rendering --displays 0 -- ./test.py : \
-np 2 -x NVIDIA_VISIBLE_DEVICES=0,1,2,3 ./pvbatch --mpi --force-offscreen-rendering --displays 1 -- ./test.py : \
-np 2 -x NVIDIA_VISIBLE_DEVICES=0,1,2,3 ./pvbatch --mpi --force-offscreen-rendering --displays 2 -- ./test.py
and I only see GPU with 0 index being used.
- Does anyone know a solution for this issue?
- If not, is there an easy way to replace a pvbatch-like workflow with a pvserver-based one?
Thank you!
