I am trying to accomplish the exact same thing as the OP. I am using a paraview server in python as the back end. The problem comes when I try to update the render from the timed thread. At first I tried something like this in my server initialize method:
def update():
while True:
self.cnt = self.cnt + 1
text.Text = str(self.cnt)
simple.Render()
self.getApplication().InvokeEvent('UpdateEvent')
time.sleep(5)
t1 = threading.Thread(target=update)
t1.start()
As soon as the thread fires however, the remote goes blank and I see this error on the console:
( 422.694s) [ BFBE5700] vtkEGLRenderWindow.cxx:569 WARN| vtkEGLRenderWindow (0x17db77f0): Unable to eglMakeCurrent: 12290
After some research, it appears that you should not call any render functions from a different thread. I changed my thread to invoke a custom event and added an observer for that event in my initialize method that updates the text. I am still seeing the same egl error.
Is there some better pattern for getting a timed callback where I can update what I am rendering without any client interaction?
Here is my full initialize method:
def initialize(self):
# Bring used components
self.registerVtkWebProtocol(pv_protocols.ParaViewWebMouseHandler())
self.registerVtkWebProtocol(pv_protocols.ParaViewWebViewPort())
pv_protocols.ParaViewWebPublishImageDelivery(decode=False))
self.registerVtkWebProtocol(pv_protocols.ParaViewWebFileListing("/home/perception", "Home", "", ""))
self.updateSecret(DemoServer.authKey)
# tell the C++ web app to use no encoding.
# ParaViewWebPublishImageDelivery must be set to decode=False to match.
self.getApplication().SetImageEncoding(0)
# Disable interactor-based render calls
simple.GetRenderView().EnableRenderOnInteraction = 0
simple.GetRenderView().Background = [0, 0, 0]
cone = simple.Cone()
text = simple.Text()
text.Text = "Hello"
simple.Show(cone)
simple.Show(text)
simple.Render()
rcallback = lambda *args, **kwargs: self.rupdate(text)
tag = self.getApplication().AddObserver('TUpdate', rcallback)
def update():
while True:
self.getApplication().InvokeEvent('TUpdate')
time.sleep(5)
t1.start()
# Update interaction mode
pxm = simple.servermanager.ProxyManager()
interactionProxy = pxm.GetProxy(
'settings', 'RenderViewInteractionSettings')
interactionProxy.Camera3DManipulators = [
'Rotate', 'Pan', 'Zoom', 'Pan', 'Roll', 'Pan', 'Zoom', 'Rotate', 'Zoom']
