Dear community,
I simulate bubble collapses.
With a pvbatch-script I want to calculate the volume of the bubble.
I use the precompiled version ParaView-5.10.0-RC1-osmesa-MPI-Linux-Python3.9-x86_64
The following function should do this:
def Process( file ):
xdmf = pv.Xdmf3ReaderS( FileName = [file] )
xdmf.CellArrays = ['levelset' ]
bubble = createThreshold( xdmf )
v = computeCellSize( bubble )
i = np.sum(v)
print(i)
return i
The ´createThreshold´ function creates a dataset which contains only the bubble, therefore the name of its result. The computeCellSize function looks like this:
def computeCellSize( input_data ):
cs = pv.CellSize(registrationName='CellSize1', Input=input_data)
cs.ComputeVertexCount = 0
cs.ComputeLength = 0
cs.ComputeArea = 0
size = cs.CellData.GetArray('Volume')
return size
It returns the volume array to the Process function. However, the i = np.sum(v) line only returns None values.
What is the reason for this?
