using "find data" aka "extract selection" with python scripting
Hi there,
I am trying to script some data processing in paraview. Specifically, importing a vti file and using “find data matching various criteria” to find the points which meet my criteria (eg: propertyX <= 0). When I using “Find Data” and run a python trace however, what I see is the following:
# create a new 'Extract Selection'
extractSelection1 = ExtractSelection(Input=dataVTI,
Selection=None)
# show data in view
extractSelection1Display = Show(extractSelection1, renderView1)
# trace defaults for the display properties.
extractSelection1Display.Representation = 'Surface'
extractSelection1Display.ColorArrayName = [None, '']
extractSelection1Display.OSPRayScaleArray = 'geometry'
extractSelection1Display.OSPRayScaleFunction = 'PiecewiseFunction'
extractSelection1Display.SelectOrientationVectors = 'None'
extractSelection1Display.ScaleFactor = 0.21600012183189393
extractSelection1Display.SelectScaleArray = 'None'
extractSelection1Display.GlyphType = 'Arrow'
extractSelection1Display.GlyphTableIndexArray = 'None'
extractSelection1Display.DataAxesGrid = 'GridAxesRepresentation'
extractSelection1Display.PolarAxes = 'PolarAxesRepresentation'
extractSelection1Display.ScalarOpacityUnitDistance = 0.6655801979167395
extractSelection1Display.GaussianRadius = 0.10800006091594697
extractSelection1Display.SetScaleArray = ['POINTS', 'geometry']
extractSelection1Display.ScaleTransferFunction = 'PiecewiseFunction'
extractSelection1Display.OpacityArray = ['POINTS', 'geometry']
extractSelection1Display.OpacityTransferFunction = 'PiecewiseFunction'
# init the 'GridAxesRepresentation' selected for 'DataAxesGrid'
extractSelection1Display.DataAxesGrid.XTitleColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.DataAxesGrid.YTitleColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.DataAxesGrid.ZTitleColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.DataAxesGrid.XLabelColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.DataAxesGrid.YLabelColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.DataAxesGrid.ZLabelColor = [0.3333333333333333, 0.0, 1.0]
# init the 'PolarAxesRepresentation' selected for 'PolarAxes'
extractSelection1Display.PolarAxes.PolarAxisTitleColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.PolarAxes.PolarAxisLabelColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.PolarAxes.LastRadialAxisTextColor = [0.3333333333333333, 0.0, 1.0]
extractSelection1Display.PolarAxes.SecondaryRadialAxesTextColor = [0.3333333333333333, 0.0, 1.0]
# hide data in view
Hide(dataVTI, renderView1)
# update the view to ensure updated data information
renderView1.Update()
I do not see anywhere in the python code where propertyX <= 0 is set. However, in the Properties of the ‘ExtractSelection1’ I see the following:
Type: Query
propertyX <= 0
Elements: Points
The points are correctly extracted. However I can only do this manually, I have not been able to automate this.
Can someone please explain how to create this extractSelection filter to specify the selection from python?
many thanks in advance
Jesse
Kitware folk? Am I correct that the trace recorder doesn’t trace find data currently?
That is correct: https://gitlab.kitware.com/paraview/paraview/issues/16836
I found a way to ‘find data’ using the following python code and get access to the arrays:
import vtk
import numpy as np
from vtk.numpy_interface import dataset_adapter as dsa
filename = 'file.vti'
# Read the file
reader = vtk.vtkXMLImageDataReader()
reader.SetFileName(filename)
reader.Update()
reader.PointArrayStatus = ['geometry', 'propertyX', 'propertyY']
usg = dsa.WrapDataObject(reader.GetOutput())
X = usg.PointData['propertyX']
Y = usg.PointData['propertyY']
then by using np.where(X > 0.0) I can filter the data I want.
However, I am missing the coordinate data.
In paraview I have access to ‘Point ID’, ‘Structured Coordinates’[tuple], ‘geometry’, ‘propertyX’, ‘propertyY’.
After running find data in paraview I have:
’Point ID’, ‘vtkOriginalPointIds’, ‘Points’[tuple], ‘geometry’, ‘propertyX’, ‘propertyY’.
Could someone please help to access the coordinate data in python and convert these to physical coordinates?
In case someone needs this in the future: (this works with the above code)
polyData = vtk.vtkPolyData()
polyData = reader.GetOutput()
coordinates = []
for i in range(polyData.GetNumberOfPoints()):
	coordinates.append(polyData.GetPoint(i))
will create a list of coordinates for each point
based on: https://www.vtk.org/Wiki/VTK/Examples/Cxx/PolyData/PolyDataGetPoint
the python recipe for your question would be:
reader = GetActiveSource() # make sure you define your active reader.
selection=SelectPoints()
selection.QueryString=“propertyX <= 0”
selection.FieldType = ‘POINT’
selection.UpdatePipelineInformation()
mySelection = ExtractSelection(Input=reader, Selection=selection)
mySelection.UpdatePipeline()
@cory.quammen
This seems relevant to the issue I was having with python state files.
I posted about this recently myself (I searched but did find this thread):
https://discourse.paraview.org/t/query-selection-not-captured-in-python-state-file/6182
But I was able to figure out the code needed because I found out that the query selection is caught by an incremental trace.
I was using 5.9.0 RC3.
