using paraview simple to load obj with texture
Hi guys,
I currently have a python vtk function that loads a obj file with texture information. Ideally I would prefer to use paraview simple for all my pipelines. I can load the mesh in paraview simple but can not find a way to load the texture as defined in the mtl file
This is the vtk function that works. Is there an equivalent in simple?
def load_vtk_mesh(self, renderer, job_path: str, source: str = "polycam", file_extension=".obj"):
        Load an OBJ mesh with optional MTL/texture into the vtk_context renderer.
        obj_file = next((f for f in os.listdir(job_path) if f.lower().endswith(file_extension)), None)
        if not obj_file:
            raise FileNotFoundError(f"No {file_extension} file found in {job_path}")
        obj_path = os.path.join(job_path, obj_file)
        # optional MTL and texture
        mtl_file = next((os.path.join(job_path, f) for f in os.listdir(job_path) if f.lower().endswith(".mtl")), None)
        texture_folder = os.path.join(job_path, "textures")
        texture_file = next((os.path.join(texture_folder, f) for f in os.listdir(texture_folder) if f.lower().endswith(".jpg")), None) \
            if os.path.isdir(texture_folder) else None
        # read OBJ
        reader = vtkOBJReader()
        reader.SetFileName(obj_path)
        reader.Update()
        polydata = reader.GetOutput()
        self.vtk_current_point_cloud = polydata
        # Apply source-specific transform
        polydata = self.apply_source_transform(polydata, source)
        # mapper & actor
        mapper = vtkPolyDataMapper()
        mapper.SetInputData(polydata)
        actor = vtkActor()
        actor.SetMapper(mapper)
        actor.GetProperty().SetRepresentationToSurface()
        # apply texture if available
        tcoords = polydata.GetPointData().GetTCoords()
        if texture_file and tcoords:
            texture_reader = vtkJPEGReader()
            texture_reader.SetFileName(texture_file)
            texture_reader.Update()
            texture = vtkTexture()
            texture.SetInputConnection(texture_reader.GetOutputPort())
            texture.InterpolateOn()
            actor.SetTexture(texture)
            self.current_texture = texture
        # <<< store the actor for later clipping
        self.current_actor = actor
        # add actor to renderer
        #renderer = self.vtk_context.renderer3D
        renderer.RemoveAllViewProps()
        renderer.SetBackground(0, 0, 0)
        renderer.AddActor(actor)
        # add grid
        self.grid_actor = None  # force re-create
        self.add_3d_grid(renderer)
        # setup camera
        bounds = self.current_actor.GetBounds()  # exact mesh bounds
        center = [(bounds[0]+bounds[1])/2, (bounds[2]+bounds[3])/2, (bounds[4]+bounds[5])/2]
        diag = max(bounds[1]-bounds[0], bounds[3]-bounds[2], bounds[5]-bounds[4])
        camera = renderer.GetActiveCamera()
        camera.SetFocalPoint(*center)
        camera.SetPosition(center[0], center[1], center[2] + diag*2)
        camera.SetViewUp(0, 1, 0)
        renderer.ResetCameraClippingRange()
        renderer.Render()
Ahh figured it out. I hadn’t enabled the advanced property settings in Paraview. Once I did this I could see how to do it using the trace.
