I tried an this is what I got It is still projecting out of the plane. I want it with the plane and nonw of them outside
, I am a beginner so help me out.
Even after that it seems to come out, I will try checking out the tutorials but I need help. Should I do it in 2D ? or how do I get the vectors in a plane for a slice in this 3D data file ?
Yeah I have tried that thanks but this isn’t what I wanted, they are all in one direction now. I want the previous image without the projections but the same direction. Thanks for helping me out but as I am a beginner I need help.
You’re still not orienting with Results. Instead, you have turned off orientation (which is why the arrows are no longer pointing in different directions).
In the Properties panel, change the Vectors combobox (under Active Attributes) to Results (right now they are still set to velocity), and click on the Orient checkbox (right below it under Orientation).
I am using 2Dglyphs. I want the arrows to show better, as you can see some arrows are represented like usual lines and not arrows. I want to change the thickness and appearance. I tried 3D glyphs but they seems to go out of the plane. I want the same image with bette appearance of arrows. Help me with it.
