Video streaming in ParaView (or even VTK)
Perhaps an off-the-wall question, and maybe will all the other Kitware options available not one worth pursuing, but I wonder if there might be an existing workflow for video streaming the ParaView rendering using RTP or something similar, perhaps using the FFmpeg libraries?
(I did a bit of searching, but Google – and even Discourse – of course think I’m asking about streamline visualization, not the streaming of video.)
Anyway, what I’d like to be able to do is render some 360/spherical views from within ParaView, and then stream that to a live viewer elsewhere. So I guess there are two issues – would an alteration to pvserver be a good solution for the streaming, since it’s already doing a form of offline rendering and sending back the images? Also, is there an easy way to do 360/spherical rendering. I know a few years ago my project-team did use ParaView for some 360 rendering, but I don’t have documentation on how we did it anymore.
I appreciate any hints or suggestions. Thanks, Bill
Use the “PanoramicProjection” plugin: https://www.kitware.com/generate-360-images-with-paraview/
That depends what you mean by that. What is that live viewer ? A screen ? A headset ? Which technology is it using ?
cc: @jaswantp
Ah, very good, thanks Mahieu, that looks like it solves half my problem.
To answer your question, my goal is to stream the video to a WebXR page that just projects it into a sphere, so an HMD on that page can look around the 360 rendering.
FYI @Scott_Wittenburg @Lucas_Givord @LucasGandel
Afaik VTK does not support WebXR, it is however supported by vtk.js
I think the simplest way forward may be to
  • Generate 360 images on a desktop computer using the component I shared above
  • Stream them using XRRemoting component (https://www.kitware.com/stream-vtk-to-the-hololens-2/, Windows only)
  • Display them using a small component able to receive streamed images and not using VTK.
I’m not entirely sure all these components can work together though.
An alternative approach would be to add support for WebXR in VTK and build VTK for the web.
This requires OpenXR extensions which are only provided by the Hololens so I don’t think it can work with another device.
We are currently working on it with @corentin.munoz
Thanks for the conversation everyone.
Followup question to Lucas: What would be the difference between using “vtk.js” with WebXR vs. VTK with WebXR?
Thanks again, Bill
VTK.js is a complete rewrite of VTK so you don’t get the exact same functionalities on both sides. Using VTK.wasm with WebXR allows you to use the VTK C++ code in a WebXR application.
