I am trying to view multiple data arrays in ParaView from a single pvtu file, but I can’t figure it out. Is this possible? For example, can I enable opacity mapping and use two color maps for two different data arrays (like qc and qg in the attached screenshot) and overlay them? The file is too big to upload but I can provide it another way if that would be helpful. Thanks in advance.
ParaView cannot display twice the same source in the same view. But as workaround, you can use the PassArrays filter, that perform only a shallow copy of the dataset (it means, no copy of the effective data), and then you have 2 pipeline sources that contain the same data.
