Visualising structures using Q-criterion in Paraview
I have loaded a state file (.pvsm) of a turbulent channel flow solved using DNS and I want to visualise vortical structures using the Q-criterion but it’s not working out.
I’m not sure what I’m missing because the tutorials seem straightforward.
The velocity components are all stored as points in 3 different arrays (u,v,w) but I can’t seem to be able to calculate the velocity magnitude with the Calculator filter. I use the equation Umag= sqrt(u^2+v^2+w^2) to find the velocity magnitude.
Any help will be appreciated and I am happy to give more information about the setup
Thanks!
Please share your data and pvsm file
flow_field.zip (58.3 KB)
I don’t know if you can or would like to open zip files.
the u, v and w velocity data are stored within .xmf files separate from the .pvsm file so I had to compress and zip them all together
thanls.
HI @akintunde_akinneye
Please share the .h5 files too.
Best,
grid3dc.h5sp (5.3 KB)
grid3du.h5sp (5.3 KB)
grid3dv.h5sp (5.3 KB)
grid3dw.h5sp (5.3 KB)
these are .h5sp files, I hope they are the same?
Many thanks
the files should be named u.res.hdf5 or similar
The files are quite heavy and for some reason I cannot upload them in this chatbox.
Is there any other way to send them to you or can something else be done?
Many thanks!
Works fine here:
Yes I can visualise the results but I seem to be having trouble calculating the Q-criterion
if you were able to, could you provide a brief walkthrough of how you did it?
thanks
How do you compute it ?
Well, assuming the research I have made is correct, the first step is to create an array (Umag) with the three velocity components (u,v,w) using the calculator filter.
I have been struggling to do this, then you use the Gradient of Unstructured Dataset 1 filter to calculate vorticity and Q criterion.
So, while my main goal is to calculate the Q criterion I haven’t been lucky to find the Umag. I get a blank box when I apply the calculator filter as shown in the image below:
It is actually pretty simple.
This is an outline, switch representation to surface to see the surface instead of the outline
The first step is to create a Vector with the three velocity components (u,v,w) using the calculator filter or the dedicated filter, MergeVectorComponents
Here is a state file: 3d_visualisation_kw.pvsm (971.6 KB)
Here are the manual steps: -
  • run ParaView
  • open u.res.xmf, Apply
  • open v.res.xmf, Apply
  • open w.res.xmf, Apply
  • select all three readers in the pipeline browser by keeping Ctrl pressed,
  • Filters → AppendAttributes, Apply
    ====== (new steps below)
  • Filters → MergeVectorComponents, select u,v,w, Apply
  • Filters → Gradient, Select “Vector”, show advanced options (cogwheel), check QCriterion, Apply
  • Switch representation to surface, show QCriterion
Thanks, I’ve been able to visualise the velocity magnitude
However, I don’t seem to have the Mergevectorcomponents filter. Perhaps it’s in a later release of Paraview?
I’m currently using v5.4.1
Yes, this is a recent filter. Please update your ParaView.
Many thanks!
It’s worked fine
