Hello, I’m trying to visualize the velocity field on a slice I created from a 3D CFD steady simulation. The problem is that the results, although appear pretty good, there are points where you can clearly see the transition between the finer and the coarser mesh zones. I attach an image of the issue and an image of the mesh, which should have enough resolution. Is there any way to change the interpolation settings or something to reduce these artefacts? I have tried the smooth filter but doesn’t seem to work. (It reads the data as “point data”).
Thank you!!!
