How do I plot vorticity contours for a falling sphere in fluid which is initially quiescent.
please share your data.
The figure in above is from Vislt. I want to get something this type of plot.
Here are the data files. I have run in parallel (4 procs) but data from two will be fine I think. foam1 is from processor 1, foam2 processor 2 and these two have relevant CFD data and solid is for sphere.
There is one of the ways to calculate a vorticity vector:
- Load foam1.csv > Table To Points Filter (TableToPoints1)
- In the same way, load foam2.csv > Table To Points Filter (TableToPoints2)
- Use the Append Geometry filter to merge TableToPoints1 and TableToPoints2 to a single point cloud.
- Use the Clean filter to remove duplicate points.
- Add the Delaunay 3D filter to turn a point cloud into a continuous volume.
- Use the Calculator filter to create a velocity vector: iHatU_0+jHatU_1+kHat*U_2
- Use The Gradient Of Unstructured Data Set filter to calculate vorticity from velocity vector.
Here is a ParaView state file that replicates the above.
vorticity.pvsm (1.1 MB)
Thanks Kyoshimi,
I tried what ever you stepped out . With same pvms file, I do not see vorticies but I can visualize other like u_0, u_2. I took screenshot just after loading in pvsm.
I followed myself to generate the visualization pipeline I get the error for filter “gradientOfUnstructureDataset”.
In this case I do not see anything.
In loading a pvsm, would you hit the eye icon on the left side of GradientOfUnstructuredDataSet1 in the pipeline browser?
I got it with pvsm. Actually I did just refresh the dataset and I can see. But its not smooth one (may be because of grid size I will check that if its).
If I want to see line contours of vorticity then how do I do that?
And when I setup pipeline myself I get the error for filter i.e. second image above.
Some additional steps might be required to see contour lines:
- Use the Calculator filter to extract y-component from a vorticity vector: Vorticity_Y
- Apply the Slice filter to cut a volume with a symmetry plane: Origin(0.625, 0.625, 5), Normal(0, 1, 0)
- Use the Contour filter to to grab contours.
This is a state file:
vorticity1.pvsm (1.4 MB)
I’m afraid that I have no idea why the error occurs.
