joni
(Joni-Pekka Kurronen)
March 13, 2019, 9:18am
1
This is old way , https://www.paraview.org/Wiki/Immersive_ParaView so added PARAVIEW_USE_VRPN, … I have got spacemouse from 3dconnexion to work whit paraview.
Is there big change done at software that I have not noted ?
cmake-gui say’s:
Plugin: ThickenLayeredCells - Filter to thicken layered cells : Enabled
Plugin: VRPlugin - Virtual Reality Devices and Interactor styles : Disabled
Plugin: VTKmFilters - VTKm many-core filters : Enabled
I do have:
-qt5-default from ubuntu ppa
-vrpm server build git hub sources
Commandline options:
-DVRPN_LIBRARY:PATH="/mpi/C5/vrpn/lib" -DVTKm_ENABLE_OPENMP:BOOL="1" -DVTK_LIBRARYES:PATH="/mpi/C5/VTK-8.2.0/lib" -DVRPN_INCLUDE_DIR:PATH="/mpi/C5/vrpn/include" -DVTK_LIBRARIES:PATH="/mpi/C5/VTK-8.2.0/lib"
Cache file:
VRPN_LIBRARY:PATH=/mpi/C5/vrpn/lib
VTKm_ENABLE_OPENMP:BOOL=1
VTK_LIBRARYES:PATH=/mpi/C5/VTK-8.2.0/lib
VRPN_INCLUDE_DIR:PATH=/mpi/C5/vrpn/include
VTK_LIBRARIES:PATH=/mpi/C5/VTK-8.2.0/lib
mwestphal
(Mathieu Westphal (Kitware))
March 13, 2019, 9:19am
2
vrpn is still the way to connect a 3D mouse.
joni
March 13, 2019, 12:56pm
3
Have you reason why it dose not compile even
all directryes and FLAGS are set ?
Is there change at Cmakefiles ?
mwestphal
March 13, 2019, 1:02pm
4
Which error are you seeing ?
joni
March 13, 2019, 1:10pm
5
I can not compiled or installed version plugin directory VRPN
plugin.
cmake-gui say’s:
mwestphal
March 13, 2019, 1:12pm
6
Your message seems incomplete.
joni
March 13, 2019, 1:15pm
7
I can not FIND compiled or installed version plugin directory
whit VRPN plugin.
So clearly paraview dose not show vrpn plugin at plugin menu
eighter.
cmake-gui say’s while converting :
mwestphal
March 13, 2019, 1:19pm
8
Please copy and paste your error.
joni
March 13, 2019, 1:21pm
9
mwestphal
March 13, 2019, 1:22pm
10
Enable the plugin in cmake ?
joni
March 13, 2019, 1:39pm
11
joni
March 13, 2019, 1:49pm
13
cmake-gui configure removes PARAVIEW_BUILD_PLUGIN_VRPlugin flag away
and say's :
Only warning from configure is non-related:
CMake Deprecation Warning at ThirdParty/IceT/vtkicet/CMakeLists.txt:14 (CMAKE_POLICY):
The OLD behavior for policy CMP0017 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
mwestphal
March 13, 2019, 3:12pm
14
I do not see this bug with ParaView 5.6.0 sources.
in your terminal, do the following:
mkdir build
cd build
cmake -DPARAVIEW_BUILD_PLUGIN_VRPlugin=ON /path/to/paraview/5.6.0/sources/
my result is:
-- Plugin: VRPlugin - Virtual Reality Devices and Interactor styles : Enabled
joni
March 13, 2019, 3:25pm
15
OK, it’s looks like if you define FLAG at cmake-gui it dispeares while creating,
IT WORK*S WHIT clean, fresh, diretory and cmake whit all flag’s like:
cmake /mpi/S5/ParaView-v5.6.0
-DCMAKE_INSTALL_PREFIX=/mpi/C5/ParaView-v5.6.0_v2
-DCMAKE_BUILD_TYPE=Release
-DBUILD_SHARED_LIB:BOOL=TRUE
-DPARAVIEW_BUILD_QT_GUI:BOOL=TRUE
-DPARAVIEW_USE_MPI:BOOL=TRUE
-DPARAVIEW_BUILD_PLUGIN_VRPlugin:BOOL=TRUE
-DVRPN_LIBRARY:PATH=/mpi/C5/vrpn/lib
-DVTKm_ENABLE_OPENMP:BOOL=1
-DVTK_LIBRARYES:PATH=/mpi/C5/VTK-8.2.0/lib
-DVRPN_INCLUDE_DIR:PATH=/mpi/C5/vrpn/include
-DVTK_LIBRARIES:PATH=/mpi/C5/VTK-8.2.0/lib
joni
March 13, 2019, 3:27pm
16
THANK ’ S
joni
ps. you can not just post wors THANK’s to forum, let’s
see if e-mail dellivers those!
joni
March 13, 2019, 3:42pm
17
cd /mpi/S5/builddir/ParaView-v5.6.0_v2
-DPARAVIEW_USE_VRPN:BOOL=TRUE
There was not TYPE selection so I try above, -DPARAVIEW_USE_VRPN:BOOL=TRUE
next,… if it work’s then
joni
March 13, 2019, 3:44pm
18
This is quite common whit cmake-gui,…
clean directory and cmake solves problems,…
It can be problem at CMAKEFILES.
