Hi, I got these outputs from the code, but when I open with VTK, it doesn’t group to one, and the sorting is not in ascending order, what can I do in Paraview? and what is the suggestion for changing the source code output?
Thank you!
Thank you!
ParaView indeed rely on naming to group file series together but clearly that doesnt work with your naming scheme.
Could you explain what you would like ?
Best,
