vtkAngularPeriodicFilter vtkCutter 2
I have a 3D VTK dataset (on the form of a 45° wedge) and I want to post-process it in a Python script (using pvbatch). I apply the following filters:
# Apply angular periodic filter
print("\tApplying angular periodic filter")
data = vtkutils.angularPeriodic_vtk(data, 45., 2, [0., 0., 0.])
print(data.GetOutput())
# Slice through data
print("\tSlicing")
data = vtkutils.cut_vtk(data, cut)
Here is the definition of the functions used above:
def angularPeriodic_vtk(data, rotationAngle, rotationAxis, center):
    angularPeriodic = vtk.vtkAngularPeriodicFilter()
    angularPeriodic.SetInputConnection(data.GetOutputPort())
    angularPeriodic.SetRotationAngle(rotationAngle)
    angularPeriodic.SetRotationAxis(rotationAxis)
    angularPeriodic.SetCenter(center)
    angularPeriodic.SetComputeRotationsOnTheFly(False)
    angularPeriodic.Update()
    return angularPeriodic
def cut_vtk(data,plane):
    cutter = vtk.vtkCutter()
    cutter.SetCutFunction(plane)
    cutter.SetInputConnection(data.GetOutputPort())
    cutter.Update()
    return cutter
The output from angularPeriodic_vtk seems fine (a vtkMultiBlockDataSet comprised of 8 children), but the output from cut_vtk is just None (i.e. all data arrays are gone)… Could you help me figure out what is going on?
Thanks a lot,
Hi Rigel,
a similar problem is described in https://discourse.vtk.org/t/vtkthreshold-not-working-with-vtkmultiblockdataset/5406 - It obviously has to do with the GetOuput() method supposed to serve a vtkUnstructuredGrid. I managed to access the cut vtkMultiBlockDataSet by using the method cutter.GetOutputDataObject(0)
