Hello everyone,
I am facing a small problem. I am trying to simulate granular assemblies in 2D. I am using 2D Glyph, circles, filled! The problem is that the disks I am getting are somehow octagonal. I have seen that they are octagonal because they are defined only by 8 points. Is there any clever way to increase the number of points to make these “octagonal” real disks?
Hope my message was clear, thank you in advance.
Nabil
If you are coding pure vtk, please go to the vtk forum.
If you are using ParaView, are you using the Glyph source or the 3D Glyph representation ?
Hello Nicolas, thank you for your reply
I am using Glyph3D
It seems that you cannot control the circle resolution directly.
So what you need is:
- create a
Diskfrom theSourcemenu. Setup the resolution you want and maybe other properties (radius will not matter here) - on your dataset, apply the
Glyph with Custom Sourcefilter, and use your disk asGlyph Source
OR use the
3D Glyphrepresentation and instead of2D glyph, selectpipeline connectionand choose your disk
