Hi guys,
I have the function below that returns all visible points in the renderer from a mesh obj. Its fast and it is accurate but my understanding is that it requires a GPU. This has been fine as locally there is a GPU but I am moving the application to the cloud and I need to remove the requirement of having to use a GPU as they are very expensive to run 24/7.
So what options are available to me? Is there an alternative that is fast and offers similar results in Paraview but does not require a GPU
def _project_points_with_hardware_selector(self, renderer, render_window, polydata, width, height):
selector = vtkHardwareSelector()
selector.SetRenderer(renderer)
selector.SetArea(0, 0, width - 1, height - 1)
selector.SetFieldAssociation(vtkDataObject.FIELD_ASSOCIATION_POINTS)
render_window.Render() # must render before selecting
selection = selector.Select()
if not selection:
print("ā No selection returned.")
return [], []
selected_points = []
projected_pixels = []
for node_idx in range(selection.GetNumberOfNodes()):
node = selection.GetNode(node_idx)
if not node:
continue
id_array = node.GetSelectionList()
if id_array is None:
continue
ids = vtk_to_numpy(id_array)
for pt_id in ids:
if 0 <= pt_id < polydata.GetNumberOfPoints():
world_pt = polydata.GetPoint(pt_id)
selected_points.append(world_pt)
x_ref = vtk.reference(world_pt[0])
y_ref = vtk.reference(world_pt[1])
z_ref = vtk.reference(world_pt[2])
renderer.WorldToDisplay(x_ref, y_ref, z_ref)
x2d = x_ref.get()
y2d = y_ref.get()
flipped_y2d = int(round(height - 1 - y2d))
projected_pixels.append((int(round(x2d)), flipped_y2d))
print(f"ā
Selected {len(selected_points)} visible points")
return projected_pixels, selected_points
