VTKHDF SplitByComposite
I have multiple vtkUnstructuredGrids which have been grouped with GroupDatasets()
Attempting to save them in VTKHDF format, I use
SaveData(‘/foo.vtkhdf’, proxy=groupDatasets1, WriteAllTimeSteps=1,
SplitByComposite=1)
The help button says that SplitByComposite would write each part of a vtkMultiBlockDataSet “in their own file”, such that each can be read individually; or did I misunderstand?
This is not happening for me. I see a single monolithic HDF5 file being written. I use v6.1.1
I just tested using ParaView 6.1.1, ParaView wrote three files as expected:
mbsplit_Block_1.vtkhdf mbsplit_Block_2.vtkhdf mbsplit.vtkhdf
The _1 and _2 files are valid .vtkhdf files.
I use the WriteAllTimeSteps=1 option. My data has Time. The attached Python code does not write three independent files.
pvTestVTKHDFWriter.py (5.1 KB)
@Louis_Gombert
SplitComposite/Partitions is not compatible with temporal datasets for now. I’ll make it clear in the documentation, all combinations of Split don’t have full compatibility with each other.
