I’m new to ParaView (5.7.0) and have hit an unexpected roadblock. Following instruction given here (see below) I am trying to build a 3D model from slices, prepared using ImageJ and MuhRec (collected via neutron tomography, so greyscale). As recommended I created raw file and applied the relevant scalar type and data extent. However, when the process always fails. I get the generic warning: In C:\bbd\ecd3383f\build\superbuild\paraview\src\VTK\IO\Image\vtkImageReader.cxx, line 307
File operation failed. row = 0, Tried to Read = 3086, Read = 0, Skip0 = 0, Skip1 = 0, FilePos = -1
ParaView is not installed in hardrive C and I’ve not been able to trace it.
I’ve run through your suggestion with a couple of times on a large (1930 slices) and small (32 slices) set but still no luck. Instead I get this error message:
ERROR: In C:\bbd\ecd3383f\build\superbuild\paraview\src\VTK\IO\Image\vtkImageReader.cxx, line 190
vtkImageReader (000002272AC90CE0): Header size: 4294769728, file ext: -1, 1542, -1, 1542, -1, 31
Do let me know if there is any additional information I can provide, and thank you for your help!
I am facing the exact same problem. Wondering if you have figured out the solution yet. I am trying to use paraview to read in some tomography data in .raw format exported from Avizo.
