Hi Every one!
I used to use VM Ubuntu to run Paraview and I had no problem. Now I am trying to use X2Go which is much easier to use. I can open Paraview without problem but when I want to load a controlDict on it to analyse a case it gives me the following error:
In build/paraview-Nojbrj/paraview 5.1.2+dfsg1/paraviewcore/ServerImplementation/core/vtksiproxy.cxx, line 310
vtkSi source proxy 0x56b01ba0d90 : failed to create vtkxdmfreader aborting for debugging purposes
and it closes Paraview suddenly. Do you know what should I do?
Thanks
