In paraview V5.6.0 I get this warning while saving a series of png files:
Generic Warning: In C:\bbd\ecd3383f\build\superbuild\paraview\src\ParaViewCore\ClientServerCore\Rendering\vtkPVRenderView.cxx, line 1805
Missing VIEW().
Nothing is wrong with the output images. I just get this warning that I never used to.
My pipeline is a Transform (translation) -> threshold (masking) -> slice -> glyph.
Jvoor,
I just tried to replicate this, and couldn’t. A few thoughts:
Edit/ Reset to Default Settings. Save your old settings, if this fixes the issue, Kitware will want copies so they can figure out what is wrong.
Please give details. What OS, what data set? Can you replicate it using Examples/ can.exo or disk_out_ref.exo? Please give every step - for instance, after glyph, how did you save screenshot? .png?
Resetting my settings did not fix the issue. I cannot reproduce the issue using the can.exo example so maybe it is linked to my data somehow. I am working with a structured (curvilinear) grids which I translate, threshold using a mask, slice down a plane and then display some glyphs based on 3D vector data. What is weird is it is only to do with this slice. When I slice in an orthogonal plane I do not get the same warning.
OS = Windows 10 64 bit. I save the screenshots using the ‘Save Animation’ tool as pngs.
Maybe this is too specific a problem. In the end the output is completely fine, but thought I would mention it in case it causes issues for someone else at a later stage.
I have the same issue. When rendering the PNG files into a sequence I got a lot of warnings as the following, for every png file that is rendered:
Blockquote
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx, line 1820
Missing VIEW().
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx, line 1637
Missing VIEW().
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx, line 1693
Missing VIEW().
Missing VIEW().
Missing VIEW().
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx, line 1805
Missing VIEW().
Then at some point Paraview crashes with ‘segmentation fault’. This error appears in 5.6.0. For 5.6.1, Paraview just crashes at the first frame of PNG rendered.
