Hi all,
I have just started using Paraview and so I apologize in advance for the question but I have not been able to find a solution.
I have a vtk file containing a set of points defined using VTK_VERTEX.
The file also contains some data defined on each point.
This is the file:
# vtk DataFile Version 4.0
Unstructured Grid Example
ASCII
DATASET UNSTRUCTURED_GRID
POINTS 6 float
0 0 0
1 0 0
2 0 0
0 1 0
1 1 0
2 1 0
CELLS 6 12
1 0
1 1
1 2
1 3
1 4
1 5
CELL_TYPES 6
1
1
1
1
1
1
CELL_DATA 6
FIELD FieldData 2
firstData 1 6 float
1.0
2.0
2.0
3.0
1.0
3.0
secondData 3 6 int
1 2 0
1 3 0
0 2 0
0 0 0
4 1 0
3 0 0
I would like to move the position of the points according to secondData using the filter warp by vector.
However, when I import the data, this filter is not available (I cannot select it).
What am I doing wrong?
Thanks in advance.
