Trophime
(Trophime)
1
I’m trying to automate some postprocessing.
I would like to generate view of fields on a deformed geometry
I’ve tried something like that:
warpByVector1 = WarpByVector(Input=input)
warpByVector1.Vectors = [“POINTS”, “elasticity.displacement”]
warpByVector1.ScaleFactor = factor
warpByVector1.UpdatePipeline()
The trouble is that, no PointData nor CellData are attached to warpObject1:
warpByVector1.PointData.keys() returns an empty list whereas input.PointData.keys() is not empty.
I must miss something.
Any hints will be great
Best
Trophime
(Trophime)
3
testAxi.pvsm (206.5 KB)
The original dataset is an Ensight Gold case.
I can sent you the original dataset if needed.
Would you need the python script that automates the post-processing?
mwestphal
(Mathieu Westphal (Kitware))
4
I’ll need this too.
I need just the needed information to reproduce the issue
Trophime
(Trophime)
5
You shall be able to download an tgz with this link CNRS CRIC
PS: I use pv 5.11 on debian Bookworm
In your script, you have
warpByVector1.Vectors = ['POINTS', 'elasticity.displacement']
However, your data has no field named elasticity.displacement. I think you mean this:
warpByVector1.Vectors = ['POINTS', 'cfpdes.elastic.displacement']
With a proper vector field to warp by, the operation succeeds and I see the keys to the PointData object that I would expect.
Trophime
(Trophime)
7
My bad. Thanks. Sorry for the trouble.
