I want to calculate perimeter of a 3D building with slice surface shown in picture attached
When I use integrate variables and view cell data in spreadsheet, it shows me length in one column. I want to know if this length is the total perimeter of three buildings? or is it something else? How do I calculate the covered area of building?
Sorry. I didn’t read yior question carefully, without the extrusion you should be able to get the area with vtkMassProperties filter
About the perimer I think you should do vtkstripper with connect contiguous segments or vtkPolydata conectivity filter, I’m not sure anout the orther and after that you need to traverse all the points of a cell polyline summimg the distamce on poimt i with point i+1
For the perimeter of each section line, it may be easier to use the Plot On Sorted Lines filter. This filter puts the section line of each building into one block and calculates the arc_length of each.
