Hello ParaView developers!
Could one please clarify when I should use SubProxy and not property and give an example?
Thank you very much!
It is proxy that is integrated into another proxy seamlessly.
see:
Examples/Plugins/Representation/Plugin/GeometryRepresentations/Representation.xml
I dont get what is written there
What is representation type?
<!-- this adds to what is already defined in PVRepresentationBase -->
<RepresentationType subproxy="MySpecialRepresentation"
text="Special Mapper" subtype="Surface" />
And what is this subproxy needed for?
<SubProxy>
<Proxy name="MySpecialRepresentation"
proxygroup="representations" proxyname="MySpecialRepresentation">
</Proxy>
<ShareProperties subproxy="SurfaceRepresentation">
<Exception name="Input" />
<Exception name="Visibility" />
<Exception name="Representation" />
</ShareProperties>
</SubProxy>
Surface, SurfaceWithEdges, Volume…
It is needed so that “MySpecialRepresentation” is added to the possible representaiton types.
What is the difference of name and proxyname for proxy/subproxy?
A proxy has a name, it should be unique.
When you set a subproxy, you give it a name, then you point which proxy to use using proxygroup and proxyname. It should correspond to a proxy name and group.
