Thanks!
I was able to install everything correctly and now able to generate the hdf file. I need a bit of help though. What I want to do is save a particle simulation (Smoothed Particle Hydrodynamics), i.e. no connectivity etc. I then want to update the particle position and properties over time in a single vtkhdf file. Currently I have:
import numpy as np
import h5py as h5
from vtkmodules.vtkCommonCore import vtkDoubleArray
from vtkmodules.vtkCommonDataModel import vtkPolyData
from vtkmodules.vtkFiltersCore import vtkAppendFilter
from vtkmodules.vtkFiltersGeometry import vtkGeometryFilter
from vtkmodules.vtkFiltersSources import vtkSphereSource
from vtkmodules.vtkIOXML import vtkXMLPolyDataWriter
import vtkmodules.numpy_interface.dataset_adapter as dsa
from vtkmodules.util.numpy_support import (numpy_to_vtk as npvtk, vtk_to_numpy as vtknp)
fType = 'f'
idType = 'i8'
connectivities = ['Vertices', 'Lines', 'Polygons', 'Strips']
def generate_geometry_structure(root):
root.attrs['Version'] = (2,1)
ascii_type = 'PolyData'.encode('ascii')
root.attrs.create('Type', ascii_type, dtype=h5.string_dtype('ascii', len(ascii_type)))
root.create_dataset('NumberOfPoints', (0,), maxshape=(None,), dtype=idType)
root.create_dataset('Points', (0,3), maxshape=(None,3), dtype=fType)
for connect in connectivities:
group = root.create_group(connect)
group.create_dataset('NumberOfConnectivityIds', (0,), maxshape=(None,), dtype=idType)
group.create_dataset('NumberOfCells', (0,), maxshape=(None,), dtype=idType)
group.create_dataset('Offsets', (0,), maxshape=(None,), dtype=idType)
group.create_dataset('Connectivity', (0,), maxshape=(None,), dtype=idType)
pData = root.create_group('PointData')
pData.create_dataset('Warping', (0,3), maxshape=(None,3), dtype=fType)
pData.create_dataset('Normals', (0,3), maxshape=(None,3), dtype=fType)
cData = root.create_group('CellData')
cData.create_dataset('Materials', (0,), maxshape=(None,), dtype=idType)
def generate_step_structure(root):
steps = root.create_group('Steps')
steps.attrs['NSteps'] = 0
steps.create_dataset('Values', (0,), maxshape=(None,), dtype=fType)
singleDSs = ['PartOffsets', 'NumberOfParts', 'PointOffsets']
for name in singleDSs:
steps.create_dataset(name, (0,), maxshape=(None,), dtype=idType)
nTopoDSs = ['CellOffsets', 'ConnectivityIdOffsets']
for name in nTopoDSs:
steps.create_dataset(name, (0,4), maxshape=(None,4), dtype=idType)
pData = steps.create_group('PointDataOffsets')
pData.create_dataset('Warping', (0,), maxshape=(None,), dtype=idType)
pData.create_dataset('Normals', (0,), maxshape=(None,), dtype=idType)
cData = steps.create_group('CellDataOffsets')
def append_data(root, poly_data, newStep=None, geometryOffset=None):
if not newStep == None:
steps = root['Steps']
steps.attrs['NSteps'] = steps.attrs['NSteps'] + 1
append_dataset(steps['Values'], np.array([newStep]))
geomOffs = []
if geometryOffset == None:
geomOffs.append(root['NumberOfPoints'].shape[0])
geomOffs.append(1)
geomOffs.append(root['Points'].shape[0])
geomOffs.append(root[connect + '/Offsets'].shape[0] - geomOffs[0])
geomOffs.append(root[connect + '/Connectivity'].shape[0])
else:
geomOffs.append(steps['PartOffsets'][geometryOffset])
geomOffs.append(1)
geomOffs.append(steps['PointOffsets'][geometryOffset])
for iC in range(len(connectivities)):
geomOffs.append(steps['CellOffsets'][geometryOffset, iC])
geomOffs.append(steps['ConnectivityIdOffsets'][geometryOffset, iC])
append_dataset(steps['PartOffsets'], np.array([geomOffs[0]]))
append_dataset(steps['NumberOfParts'], np.array([geomOffs[1]]))
append_dataset(steps['PointOffsets'], np.array([geomOffs[2]]))
append_dataset(steps['CellOffsets'], np.array(geomOffs[3:3+len(connectivities)]).reshape(1, len(connectivities)))
append_dataset(steps['ConnectivityIdOffsets'], np.array(geomOffs[3+len(connectivities):3+2*len(connectivities)]).reshape(1, len(connectivities)))
append_dataset(steps['PointDataOffsets/Warping'], np.array([root['PointData/Warping'].shape[0]]))
append_dataset(steps['PointDataOffsets/Normals'], np.array([root['PointData/Normals'].shape[0]]))
append_dataset(steps['CellDataOffsets/Materials'], np.array([root['CellData/Materials'].shape[0]]))
else:
steps['NumberOfParts'][-1] += 1
append_dataset(root['NumberOfPoints'], np.array([poly_data.GetNumberOfPoints()]))
append_dataset(root['Points'], poly_data.Points)
cellArrays = [poly_data.GetVerts(), poly_data.GetLines(), poly_data.GetPolys(), poly_data.GetStrips()]
for name, connect in zip(connectivities, cellArrays):
ca = vtknp(connect.GetConnectivityArray())
append_dataset(root[name]['NumberOfConnectivityIds'], np.array([ca.shape[0]]))
append_dataset(root[name]['Connectivity'], ca)
oa = vtknp(connect.GetOffsetsArray())
append_dataset(root[name]['NumberOfCells'], np.array([oa.shape[0]-1]))
append_dataset(root[name]['Offsets'], oa)
append_dataset(root['PointData']['Warping'], poly_data.PointData['Warping'])
append_dataset(root['PointData']['Normals'], poly_data.PointData['Normals'])
append_dataset(root['CellData']['Materials'], poly_data.CellData['Materials'])
def append_dataset(dset, array):
origLen = dset.shape[0]
dset.resize(origLen + array.shape[0], axis=0)
dset[origLen:] = array
def generate_static_spheres():
sphereSrc0 = vtkSphereSource()
sphereSrc0.Update()
sphere0 = dsa.WrapDataObject(sphereSrc0.GetOutput())
sphereSrc1 = vtkSphereSource()
sphereSrc1.SetCenter(2.0, 2.0, 2.0)
sphereSrc1.SetThetaResolution(20)
sphereSrc1.SetPhiResolution(20)
sphereSrc1.Update()
sphere1 = dsa.WrapDataObject(sphereSrc1.GetOutput())
warping0 = npvtk(np.cross(sphere0.Points, [0, 0, 1]).astype(fType))
warping0.SetName('Warping')
sphere0.GetPointData().AddArray(warping0)
warping1 = npvtk(np.cross(sphere1.Points - [2, 2, 2], [0, 0, 1]).astype(fType))
warping1.SetName('Warping')
sphere1.GetPointData().AddArray(warping1)
mats0 = npvtk(np.full((sphere0.GetNumberOfCells(),), 0, dtype=idType))
mats0.SetName('Materials')
sphere0.GetCellData().AddArray(mats0)
mats1 = npvtk(np.full((sphere1.GetNumberOfCells(),), 1, dtype=idType))
mats1.SetName('Materials')
sphere1.GetCellData().AddArray(mats1)
return [sphere0]
def generate_morphing_spheres(t, morphGeometry=False):
pds = generate_static_spheres()
for pd in pds:
mod = (np.sin(pd.Points[:, 0]) + np.sin(pd.Points[:,1])+1)*np.cos(np.pi*t)/2.0
if morphGeometry:
pd.Points = pd.Points * mod
warped = npvtk(pd.PointData['Warping'] * mod)
warped.SetName('Warping')
pd.GetPointData().AddArray(warped)
return pds
def write_vtp(filepath, pds):
appender = vtkAppendFilter()
for iPD, pd in enumerate(pds):
appender.AddInputData(pd.VTKObject)
appender.Update()
surface = vtkGeometryFilter()
surface.SetInputConnection(appender.GetOutputPort())
surface.Update()
writer = vtkXMLPolyDataWriter()
writer.SetFileName(filepath)
writer.SetInputConnection(surface.GetOutputPort())
writer.Update()
def generate_data(root):
# ts = np.linspace(0.0, 0.5, 6)
# for iT, t in enumerate(ts):
# pds = generate_morphing_spheres(t)
# append_data(root, pds[0], newStep=t, geometryOffset=(None if t == 0.0 else 0))
# write_vtp('hdf_transient_poly_data_' + str(iT).zfill(3) + '.vtp', pds)
ts = np.linspace(0.6, 0.9, 4)
pds = generate_morphing_spheres(t, True)
append_data(root, pds[0], newStep=t, geometryOffset=None)
# write_vtp('hdf_transient_poly_data_' + str(iT + 6).zfill(3) + '.vtp', pds)
if __name__ == "__main__":
f = h5.File('polydata_transient.vtkhdf', 'w')
root = f.create_group('VTKHDF')
generate_data(root)
f.close()
Where I commented out some code to generate the individual files etc. these are not of interest for me, only the combined final one is.
