- def add_arguments(parser):
          -     parser.add_argument("--virtual-env", default=None, help="Path to virtual environment to use")
          -     parser.add_argument("--data", default=os.getcwd(), help="path to data directory to list, or else multiple directories given as 'name1=path1|name2=path2|...'", dest="path")
          -     parser.add_argument("--load-file", default=None, help="File to load if any based on data-dir base path", dest="file")
          -     parser.add_argument("--color-palette-file", default=None, help="File to load to define a set of color map", dest="palettes")
          -     parser.add_argument("--no-built-in-palette", help="If provided, disables built-in color maps", action="store_true", dest="hide_built_in_color_maps")
          -     parser.add_argument("--ds-host", default=None, help="Hostname to connect to for DataServer", dest="dsHost")
          -     parser.add_argument("--ds-port", default=11111, type=int, help="Port number to connect to for DataServer", dest="dsPort")
          -     parser.add_argument("--rs-host", default=None, help="Hostname to connect to for RenderServer", dest="rsHost")
          -     parser.add_argument("--rs-port", default=11111, type=int, help="Port number to connect to for RenderServer", dest="rsPort")
          -     parser.add_argument("--reverse-connect-port", default=-1, type=int, help="If supplied, a reverse connection will be established on the given port", dest="reverseConnectPort")
          -     parser.add_argument("--exclude-regex", default=_VisualizerServer.excludeRegex, help="Regular expression for file filtering", dest="exclude")
          -     parser.add_argument("--group-regex", default=_VisualizerServer.groupRegex, help="Regular expression for grouping files", dest="group")
          -     parser.add_argument("--plugins", default="", help="List of fully qualified path names to plugin objects to load", dest="plugins")
          -     parser.add_argument("--proxies", default=None, help="Path to a file with json text containing filters to load", dest="proxies")
          -     parser.add_argument("--no-auto-readers", help="If provided, disables ability to use non-configured readers", action="store_true", dest="no_auto_readers")
          -     parser.add_argument("--save-data-dir", default='', help="Server directory under which all data will be saved", dest="saveDataDir")
          -     parser.add_argument("--viewport-scale", default=1.0, type=float, help="Viewport scaling factor", dest="viewportScale")
          -     parser.add_argument("--viewport-max-width", default=2560, type=int, help="Viewport maximum size in width", dest="viewportMaxWidth")
          -     parser.add_argument("--viewport-max-height", default=1440, type=int, help="Viewport maximum size in height", dest="viewportMaxHeight")
  This file has been truncated. show original
