Dear Paraview community,
I use Paraview 5.9.1. I’m encountering issues while exporting the svg plots from paraview into ms word.
The plots are fine in paraview window but in word I see unwanted very thin whitish slant lines as in the image uploaded from word.
I tried using online tools to clean svg which works but a very tedious activity.
Please help me resolve the problem
Below is the svg file which if loaded in word would show thin slant lines. I believe it has got something to do with shape-rendering=“crispEdges”
Dear Mr. Mathieu Westphalm,
Thank you for your reply. I tried adjusting those parameters but havn’t been able to arrive at the best settings to overcome my issue. Do you have suggstions, please !
Actually, you are right. When I tried to load the svg in other image viewer, the thin lines don’t show up. Not sure why ms word shows those thin white lines.
Ideally the option shape-rendering=crispEdges should have taken care to not show up the polygon edges, however, ms word still shows them in the form of ultra thin white lines.
I’ve seen Word do this with SVGs for another modelling package called ABAQUS - it might be a Word issue. It drives me bananas. You might be able to convert SVG to the Windows format EMF, which in my experience is the most bulletproof format for high-res Word figures…
