like the title.
Not a ParaView question.
I want to compile Paraview from source with openvdb(https://gitlab.kitware.com/vtk/vtk/-/merge_requests/8024) converting writer but always get stuck in the processing.Please help me.
Why do I always get stuck installing more than 340 packages when compiling ParaView on Ubuntu 20
Because ParaView has many dependencies, however 340 seems a bit too much, which package are you installing ?
Please share your error and edit the title of this topic to reflect your actual question
There in no error output.Just get stuck when building …cxx.o[348/20699] and mouse can not be moved.
You are running out of memory, probably during VTKm compilation. Reduce the number of process you are using.
ninja -j2 ?
How to reduce the number of process?
git clone --recursive https://gitlab.kitware.com/paraview/paraview.git
mkdir paraview_build
cd paraview_build
cmake -GNinja -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_SMP_IMPLEMENTATION_TYPE=TBB -DCMAKE_BUILD_TYPE=Release …/paraview
ninja
ninja -j2 is indeed the way to fix this.
Get stuck again.I will try in other computer.
ninja -j 1 ?
It’s the computer’s problem.
