Wireframe coloring issue: shared boundary between two regions shows mixed colors
Hi everyone,
When visualizing my mesh in Wireframe mode, I color the mesh using a cell-based tag array (for example, region IDs 15 and 16). However, on the shared boundary between the two regions, the edges appear partly in the color of region 15 and partly in the color of region 16.
This results in a “half-and-half” effect on the interface, instead of using a single consistent color along the boundary.
My questions are:
Is this behavior expected in ParaView’s wireframe rendering?
How does ParaView decide which cell’s color is used for a shared edge?
Is there a way to force all shared edges to use the color of one specific region (e.g., region 16)?
I would like the interface between the two regions to show one unified color, not a mixture of both.
Any suggestions or explanations would be greatly appreciated!
Thanks!
Laplace_gmsh.xdmf (1.1 KB)
Yes, although it could be improved.
It probably related to an internal edge ordering
You may be able to achieve better results by splitting the cells entirely
In any case, please share your data (not only the xdmf file)
I have uploaded the corresponding .h5 files together with the XDMF files so that the full dataset can be loaded properly.
I would also like to ask for clarification regarding the shared-edge coloring issue:
Do I need to assign explicit physical/region IDs to the common boundary during the mesh generation process?
If this is required for ParaView to handle shared edges consistently, I can regenerate the mesh and provide a new .h5 files with the boundary regions explicitly marked.
Thank you for your help, and please let me know if any additional data is needed.
lagrangian_mesh.h5 (33.5 KB)
are you sure this is the right h5 file ? the xdmf file refers to Laplace_gmsh.h5
Laplace_gmsh.h5 (33.5 KB)
Thanks for pointing this out. I uploaded the wrong .h5 file by mistake. I’ve now corrected it and uploaded the proper file. Sorry for the confusion.
Here you go:
Although I have to save it into an unstructured grid first:
vtm_1_0.vtu (20.5 KB)
And then use ExplodeDataSet
Thank you for your reply. I loaded the .vtu file you provided into ParaView, but I cannot find the ExplodeDataSet filter in the Filters menu.
Could you please provide the exact steps ?
I may be missing something in the interface.
Thank you again for your help!
@mwestphal may have been referring to the Shrink filter, which is ironically most often used to create an exploded view of a mesh.
Well, no, I mean the filter called ExplodeDataSet, but its a pretty recent filter only available in 6.0 release of ParaView that you can download here: https://www.paraview.org/download/
It split a dataset into a composite dataset based on the value on the cells.
Here is how to do it:
  • Download latest nightly
  • File → open → vtm_1_0.vtu → Apply
  • Filters → ExplodeDataSet → Apply
  • Wireframe repr
Shrink is indeed also a solution but requires gap between cells.
Yup, my bad. I saw that there is an Explode Data Set filter in ParaView 6.0.1 right after I sent off my message.
Thanks for the clarification! I’ll download the latest ParaView build and try it following your steps. Really appreciate the guidance!
