This potential ParaView bug is observed inside the code of a property widget that belongs to some self-written filter plugin. The same property widget worked fine in versions of ParaView up to 5.10, but not any more with 5.12.0
The property widget is declared like this:
class ATGPROPERTYWIDGETSMODULE_EXPORT widSelectionIds: public pqPropertyGroupWidget
Within the constructor, the following code is supposed to catch all selection changes:
pqSelectionManager* selMan = getSelectionManager();
connect(selMan, SIGNAL(selectionChanged(pqOutputPort*)),
SLOT(handleChangedSelection(pqOutputPort*)));
Now withing the handleChangedSelection() function, I want to retrieve the current selection. This is not any more so simple as it used to be in the past, but the following code should bring me there:
vtkSMSourceProxy *appendSelections = nullptr,
*activeSelection = nullptr;
appendSelections = vtkSMSourceProxy::SafeDownCast(outPort->getSelectionInput());
if((nullptr != appendSelections) &&
(0 < vtkSMPropertyHelper(appendSelections, "Input").GetNumberOfElements()))
activeSelection = vtkSMSourceProxy::SafeDownCast(
vtkSMPropertyHelper(appendSelections, "Input").GetAsProxy(0));
In the past, the extra step to “unwrap” the active selection from some “append selection” thing was not required, but that’s fine and there is certainly a good reason for this change.
And the above code does work and I can now analyze the “active selection” in the same ways like in the past, such as checking the type of the selection, convert it if required, etc. etc.
However the new problem is that it works only once!
Meaning that if in my render view I select one cell, with “Interactive Select Cells On”, the property widget receives a signal and runs through the above code and I can retrieve the cell id of that newly selected cell.
If now I click on another cell, adding it thus to the selection, the property widget will again get a signal. But if now it extracts the “active selection” in the above way, this selection still contains only the first selected cell id, not the second! And also not any further cell.
Conclusion: It looks like the selection manager is sending the message about selectionChanged, but at the same time it is not able to provide an updated “active selection”, but instead always returns the first one on request.
Is it possible that the selection manager now needs an additional “kick” in the form of some “update” call or whatever in order to retrieve the active selection from the server side not only once, but each time there is a change?
