Dear all,
I couldn’t quite find this information on the web so I decided to just go ahead and ask:
When opening an Xdmf-file I am asked to choose between the following three readers. Are the first two equal?
Someone else was claiming to see different behaviours for all three of them:
https://public.kitware.com/pipermail/paraview/2016-April/036756.html
The docs (https://www.paraview.org/ParaView/Doc/Nightly/www/py-doc/paraview.simple.XDMFReader.html) are not helpful either.- Xdmf3 Reader,
- Xdmf3 Reader (Top Level Partition),
- Xdmf Reader
my .xmf file typically looks like the one below. I have to load it using the Xdmf-reader, because the other two connot handle HyperSlabs. Can I expect the referenced file to be read with MPI-parallelized file access?
I did a test on a 16GB-file and noticed that all my pvserver processes have a CPU load of 100%, but only the memory consumption of one was increasing during the reading phase. The reading process felt long, but I’m not sure here. -
Some Xdmf2-reader was claimed to do automatic parallel decomposition of structured data under some circumstances (“The xdmf3 reader does not do automatic parallel decomposition of structured data like xdmf2 reader did.”, https://gitlab.kitware.com/paraview/paraview/issues/17295). Where is that Xdmf2 reader hidden?
If I cannot get to have Paraview read my (PETSc) binary files in parallel, then post-processing is not feasible this way.
My backup plan is to write a parallelized Fortran Code that would load the binary files and hand them over to Paraview using the in-situ/Catalyst library. https://www.paraview.org/in-situ/
The same code could then of course be integrated into the main simulation code to avoid the storage of intermediate files if desired. For now though, I’m concerned with the processing of already existing data.
I would really appreciate if someone shed some light on this this issue.
Sample .xmf file
<?xml version="1.0" ?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" [
<!ENTITY xst "6.250000000000710E-004 1.250000000000000E-003 1.875000000000071E-003 ...">
<!ENTITY yst "0.000000000000000E+000 6.249999999999977E-004 1.249999999999995E-003 ...">
<!ENTITY zst "6.250000000000000E-004 1.250000000000000E-003 1.875000000000000E-003 ...">
<!ENTITY xce "3.125000000000355E-004 9.375000000000355E-004 1.562500000000036E-003 ...">
<!ENTITY yce "-3.124999999999989E-004 3.124999999999989E-004 9.374999999999966E-004 ...">
<!ENTITY zce "3.125000000000000E-004 9.375000000000000E-004 1.562500000000000E-003 ...">
<!ENTITY gridx "0 6.250000000000710E-004 1.250000000000000E-003 1.875000000000071E-003 ...">
<!ENTITY gridy "-0.000625 0.000000000000000E+000 6.249999999999977E-004 1.249999999999995E-003 ...">
<!ENTITY gridz "0 6.250000000000000E-004 1.250000000000000E-003 1.875000000000000E-003 ...">
<!ENTITY gridNx "2049" >
<!ENTITY gridNy "339" >
<!ENTITY gridNz "1025" >
<!ENTITY Nx "2048" >
<!ENTITY Ny "338" >
<!ENTITY Nz "1024" >
<Xdmf Version="2.0" xmlns:xi="http://www.w3.org/2001/XInclude" >
<Domain>
<Grid Name="staggered_east" GridType="Uniform">
<Topology TopologyType="3DRectMesh" NumberOfElements="&Nz; &Ny; &Nx;"/>
<Geometry GeometryType="VXVYVZ">
<DataItem Dimensions="&Nx;" NumberType="Float" Precision="4" Format="XML"> &xst; </DataItem>
<DataItem Dimensions="&Ny;" NumberType="Float" Precision="4" Format="XML"> &yce; </DataItem>
<DataItem Dimensions="&Nz;" NumberType="Float" Precision="4" Format="XML"> &zce; </DataItem>
</Geometry>
<Attribute Name="u" AttributeType="Scalar" Center="Node">
<DataItem ItemType="HyperSlab" Dimensions="&Nz; &Ny; &Nx;" Type="HyperSlab">
<DataItem Dimensions="3 4" Format="XML">
0 0 0 0
1 1 1 1
&Nz; &Ny; &Nx; 1
</DataItem>
<DataItem
ItemType="Uniform"
Name="u_raw"
Format="Binary"
Dimensions="&Nz; &Ny; &Nx; 3"
DataType="Float" Precision="8" Endian="Big" Seek="8"
uvw_000642.bin
</DataItem>
</DataItem>
</Attribute>
</Grid>
</Domain>
</Xdmf>
