Dear all,
I am trying to load a single component of a vector field stored in the file uvw_000001.bin.
I am using the XDMF file below which loads the field values into the variable q just fine, i.e. I can view its components in Paraview.
The second variable u where I try to extract the first component of the vector field is not available in Paraview.
What am I doing wrong?
<?xml version="1.0" ?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf Version="3.0">
<Domain>
<Grid Name="staggered_east" GridType="Uniform">
<Topology TopologyType="3DRectMesh" NumberOfElements="34 34 34"/>
<Geometry GeometryType="VXVYVZ">
<DataItem Dimensions="34" NumberType="Float" Precision="4" Format="XML">
0.0000000000000000 0.10000000000000001 0.20000000000000001 0.30000000000000004 0.40000000000000002 0.50000000000000000 0.60000000000000020 0.70000000000000007 0.80000000000000004 0.90000000000000002 1.0000000000000000 1.1000000000000001 1.2000000000000002 1.3000000000000000 1.4000000000000001 1.5000000000000000 1.6000000000000001 1.7000000000000002 1.8000000000000000 1.9000000000000001 2.0000000000000000 2.1000000000000001 2.2000000000000002 2.3000000000000003 2.4000000000000004 2.5000000000000000 2.6000000000000001 2.7000000000000002 2.8000000000000003 2.9000000000000004 3.0000000000000000 3.1000000000000001 3.2000000000000002 3.3000000000000003
</DataItem>
-5.0000000000000003E-002 5.0000000000000003E-002 0.15000000000000002 0.25000000000000000 0.35000000000000003 0.45000000000000001 0.55000000000000004 0.65000000000000013 0.75000000000000000 0.85000000000000009 0.94999999999999996 1.0500000000000000 1.1500000000000001 1.2500000000000000 1.3500000000000001 1.4500000000000002 1.5500000000000000 1.6500000000000001 1.7500000000000000 1.8500000000000001 1.9500000000000002 2.0499999999999998 2.1500000000000004 2.2500000000000000 2.3500000000000005 2.4500000000000002 2.5499999999999998 2.6500000000000004 2.7500000000000000 2.8500000000000005 2.9500000000000002 3.0499999999999998 3.1500000000000004 3.2500000000000000
</DataItem>
</DataItem>
</Geometry>
<Attribute Name="q" AttributeType="Scalar" Center="Node">
<DataItem
ItemType="Uniform"
Name="uvw_s"
Format="Binary"
Dimensions="34 34 34 3"
DataType="Float" Precision="8" Endian="Big" Seek="8"
uvw_000001.bin
</DataItem>
</Attribute>
<Attribute Name="u" AttributeType="Scalar" Center="Node">
<DataItem
ItemType="HyperSlab"
Dimensions="34 34 34 1"
Type="HyperSlab">
<DataItem
Dimensions="3 4"
Format="XML">
0 0 0 0
1 1 1 1
34 34 34 1
</DataItem>
<DataItem
ItemType="Uniform"
Name="uvw"
Format="Binary"
uvw_000001.bin
</DataItem>
</DataItem>
</Attribute>
</Grid>
</Domain>
</Xdmf>
uvw_000001.bin (921.2 KB)
