Dear All,
I can not load a xdmf file (with either of the readers) in PV 5.9.0 while all readers work in PV 5.8.1. Is this a known issue?
I am using these test files:
test.xmf (828 Bytes)
test.h5 (6 KB)
The problem was an HDF5 library that is loaded with module load hdf5. The hdf5 files wrapped in the xdmf caused the crash when paraview tried to load the data with the particular HDF5 library loaded. The same configuration is/was working in paraview 5.8 or below.
