XDMF reader failing to load matrix attribute
I am using ParaView 6.2 and now matrix attributes are failing to load properly. I have a 2D array of data in an HDF5 file of size 10000 x 3. It’s defined in my XDMF file as follows.
<Attribute AttributeType="Matrix" Center="Node" Name="Attribute1">
        <DataItem Dimensions="10000 3" DataType="Float" Precision="8" Format="HDF">
          file.h5:/GroupName/Attribute1
        </DataItem>
</Attribute>
When I load the file and try to view the data array, ParaView freezes and the console outputs the following continuously for each row
[paraview ] vtkTable.cxx:429 ERR| vtkTable (0x223a5220): Column "Attribute1_0" must have 10000 rows, but has 1.
I’ve verified the format in my HDF5 file and it is in fact a 2D array of 64-bit floats with 3 columns. I am using the standard XDMFreader. Loading Scalar attributes works fine.
Thanks,
Sam
Do you know if this was loadable with any previous version of ParaView? I ask because if it was, there is a regression somewhere. If it wasn’t, this may be an unsupported feature in the XDMF Reader.
Yes, it works on version 6.0.0
Okay, thanks. Is it possible to post here or somewhere else an example data file that shows this error? Ideally we could add it to our testing sweet to avoid a similar regression in the future.
