Add feature to evenly distribute views
Problem: If a user wants to create a layout of views that are divisible by two, it’s quite simple to get an even distribution of these views using the split icons:
However, if the user wants a layout of say, three images, it’s quite onerous to do so. Also, there have been a handful of times where I’ve accidentally moved the dividing line between a “power of two” layout and it’s painful to get back to an even distribution again.
For example, here’s me trying to use the GUI to make a 1x3 layout of results:
I’m then left with either dragging the dividing lines back and forth to get close to an even distribution, or I’ve got to load up a Python shell and run a trace command in order to script this.
Proposed Feature:
Some functionality in ParaView that does one or more of the following:
  • Lets the user specify the relative width & height for each view in a layout,
  • Lets the user add a “dimension constraint” between two or more views to set one or more of their dimensions to be equal.
  • Lets the user select multiple contiguous views and distribute [horizontally | vertically] similar to PowerPoint.
  • Other?
A simpler idea would be as follows:
Add two new buttons next to the split buttons: distribute horizontally, distribute vertically.
When clicked, all views will be distributed in the wanted direction. Eg:
become:
Mathieu, good idea. https://gitlab.kitware.com/paraview/paraview/-/issues/20788.
And Greg, thanks for the “nudge”.
Is this feature available to use? I need to evenly distribute the windows!
It was added in https://gitlab.kitware.com/paraview/paraview/-/merge_requests/4719 and will be available in ParaView 5.12.0. It is available right now in the nightly builds available at www.paraview.org/download.
To use, Ctrl/right click on the Layout tab above the views and select the menu item named “Rearrange Views” and select an option.
Very cool!
Dear Cory, thanks for this feature. I wonder if there is a python command for this Equalize Views? It seems this command is not available to be traced in the ParaView GUI.
Thanks in advance.
@nicolas.vuaille any plans to expose in Python?
I have no plan to improve python support, but it is already available:
GetLayout().SMProxy.EqualizeViews()
Or for specfic direction:
GetLayout().SMProxy.EqualizeViews(paraview.modules.vtkRemotingViews.vtkSMViewLayoutProxy.HORIZONTAL)
I think it should be very easy to add that in simple.py
paraview.simple functions added in https://gitlab.kitware.com/paraview/paraview/-/merge_requests/6962
