hello,
context: User is using trace on, of for example, lagrangean particles, uses Glyph over a cloud of points, set the Glyph to spheres and change its radius. saves the hole script to use it later.
issue/situation for this improvement to take place: There are a bunch of ‘settings’ that we set during the trace that are not saved, such as the radius of the spheres of the glyph. This can be problematic for two reasons:
- one needs to dig on the documentation how to change it each time.
- if one does not realize and the default 0.5 mm is not good for our current simulation the screenshots if we do not realize will be quite bad.
I am sure that there were other settings that were not saved but right now i can not remember which ones…
proposal: save this kind of settings while doing the trace.
