Hello all,
I have an AMR data set where the data is only stored on the leaf nodes. Thus all datasets come up as partial, which is fine. However, the calculator does not seem to work with them. It cannot parse the equations that I give it that use any of the data. Once I perform some filter on the amr data set, like a slice, and the dataset is no longer partial, the calculator works. Is there something I’m missing? Seems like I should be able to create expressions from partial datasets.
Thank you all
