For one project I’m currently stuck using PV v5.6 and I need to use the Calculator on a vtkOverlappingAMR dataset with partial datasets. This doesn’t work, as has been previously mentioned here.
I know that this has been fixed at least as of 5.9, but bear with me…
What’s the simplest way to programmatically (Python) remove partial datasets/to extract the lowest-level AMR cells?
I’ve found I can either:
- Apply a
Thresholdfilter using any scalar and set the min/max to the actual scalar min/max - Apply an
ExtractAMRBlocksfilter and generate theSelectedDataSetsvalue for the lowest level
Anything more straight-forward than those?
