Hello everybody,
I would like to have more information about Resample With Dataset filter.
I read the topic : plot difference between two slices
But i could not imagine to use the Rename Array and the transform filters.
So the question is : why does exactly the Resample filter? And why do we have to use the rename … and transform filters ?
This is to prevent further errors i could do in the future.
For example, i use the Resample filter directly to compare to systems (same bouds, but differents meshes) in 2D. And that works.
But at that time, i would like to compare two slides coming from the same 3D system, but 2slides with a rotation in between. And using the Resample… does not work.
Many thanks for explanations
BR
