Hello everyone,
I use a 3D code for solving Euler equations in a cylindrical geometry.
The structure of my output ( an hdf5 file ) looks like :
Mesh
gas/mesh/x : 1D array of dimension nx containing all r values
gas/mesh/y : 1D array of dimension ny containing all theta values
gas/mesh/z : 1D array of dimension nz containing all z values
Physical variables
gas/rho : 3D array of dimension nz,ny,nx
gas/p : 3D array of dimension nz,ny,nx
I want to use Paraview in order to visualize my output data but it is not read.
I read that apparently I have to change the format of my data. Thus I want to know, please, to which format I should convert my data ? (If possible the easiest way). If possible I would like to have an example of what my data should look like.
If needed in the following link you can find an example of my file : https://nuage.osupytheas.fr/s/W5y3eRPXM9C7geH
Thank you in advance for your help,
Steven
