I have a csv file with 6 columns. 3 of them X,Y,Z coordinate data, 3 of them u,v,w velocity data. I can view my points using TabletoPoints. However I couldn’t attach the velocity vectors to the points. How can I do that?
- Try Table to Structured Grid filter. Refer to [read CSV data]. Refer to read csv data
- You can also manually transform your csv data into vtk data(probably ImageData). The XYZ coordinate data becomes dimensions while the uvw velocity data becomes vector field. Refer to file-formats
Thank you, converting it to vtk file has worked.
Can you describe the problem you encountered?
