I have some problem with the latest versions of Paraview (from 5.8 at least) . When I load data from a pvtr file, data are out of range (-1E+38 , 1E+38). All is right when I directly load data from vtr files (files present in the pvtr file, which are in binary format).
The problem occurs with different OS (MacOS, Linux).
Loading data from my .pvtr file works well with an oldest version of Paraview (5.0.1 64).
Please, could you help me to understand and solve this problem ?
Thank you for your help.
You find here the pvtr file I used. Every data features (the data type, the byte order) are identical to these defined in the .vtr files.
<?xml version='1.0' encoding='utf-8'?>
<VTKFile type="PRectilinearGrid" version="1.0" byte_order="LittleEndian" header_type="UInt32">
<PRectilinearGrid WholeExtent="0 513 0 257 0 0 " GhostLevel="0">
<PPointData>
<PDataArray type="Float32" Name="Velocity" NumberOfComponents="2" format="binary"/>
<PDataArray type="Float32" Name="T" NumberOfComponents="1" format="binary"/>
</PPointData>
<PCoordinates>
<PDataArray type="Float32" Name="X" NumberOfComponents="1" format="binary"/>
<PDataArray type="Float32" Name="Y" NumberOfComponents="1" format="binary"/>
<PDataArray type="Float32" Name="Z" NumberOfComponents="1" format="binary"/>
</PCoordinates>
<Piece Extent="0 257 0 129 0 0 " Source="res_00000_0000149.vtr"/>
<Piece Extent="0 257 128 257 0 0 " Source="res_00001_0000149.vtr"/>
<Piece Extent="256 513 0 129 0 0 " Source="res_00002_0000149.vtr"/>
<Piece Extent="256 513 128 257 0 0 " Source="res_00003_0000149.vtr"/>
</PRectilinearGrid>
</VTKFile>
