Description of XML configuration files.
Help me find documentation on XML configuration files describing the behavior of filters. What I found is not a complete description. There is a text
   <StringVectorProperty command="SetInputArrayToProcess"
                         element_types="0 0 0 0 2"
                         name="SelectInputVectors"
                         label="Input Array"
                         number_of_elements="5">
What values can parameters take? Is there a list of valid parameters? For example, there is this line
                         element_types="int int str int double double int str"
When to use what values? Sometimes string values are used, sometimes numeric.
Lots of goof info here:
Also this one about SetInputArrayToProcess
https://vtk.org/doc/nightly/html/classvtkAlgorithm.html
