Error loading result of fluent in paraview
Hi
When I open the results of a simulation in Fluent, I get an error:
ERROR: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\EnSight\vtkGenericEnSightReader.cxx, line 441
vtkPGenericEnSightReader (000002B87F93D9D0): Unable to open file: C:\Users\mohseniankoochaksa.s\Desktop\try\gg_files\dp0\FFF\Fluent\ensight/“Ensight-files.geo”
Warning: In C:\glr\builds\paraview\paraview-ci\build\superbuild\paraview\src\VTK\IO\EnSight\vtkGenericEnSightReader.cxx, line 442
vtkPGenericEnSightReader (000002B87F93D9D0): Assuming binary file.
I should mention that I am using Ansys 2021 R1. I used to use Ansys 2019 before and it didn’t get any error post processing with ParaView.
What is the problem? What can i do?
Help me, please!
In newer versions of Fluent, in EnSight case files (*.encas), the file names are now enclosed in double quotes, which seems to be causing the failure in ParaView. In addition, the SCRIPTS entry needs to be removed.
Therefore, in the encas file, the following red characters need to be removed.
Thanks
Thank you very much for your reply. It totally solves the error.
But I have to mention that the “quote” problem is solved in Paraview 5.12.0-RC3. So you do not need to modify *.encas file anymore.
See the screenshot below:
