I am following this tutorial but found that in 5.8, there is no “Export Inspector” in the View menu
Is that being replace by something else or removed because it is deprecated ?
Cheers
Cheers
That is correct. It’s been replaced by Extractors.
If you’re keen, check this discussion out. The extractors are documented in the Guide here.
The Cinema tutorial will be updated soon to reflect the new workflow.
Correction, it hasn’t been removed in 5.8, but in 5.9 is where it’s removed.
