I missed the webinar so thanks for sharing that video.
What was the name of the HDF5 format that was recommended for reading FEA data into Paraview please? How does it compare to MED? Are they equivalent or is one a subset of the other?
Also is it possible to show bars or lines, instead of arrows with cone heads, in the glyph view and superimpose 2 or 3 eigenvectors in the same visualisation? Thanks.
VTKHDF. Itβs the recommended format for anything that go into ParaView, not only FEM.
Way better in terms of performance and integration in ParaView.
Iβd say there are some difference, especially because MEDReader as some modal operation built-in that you need to emulate with filters in ParaView if you need them.
Yes, change the glyph type
Yes, use PassArrays filter to duplicate the source and show it multiple times using 3d glyphs representation
