currently, filters such as “Plot Over Line” or “Probe Location” and tools like “Hover Points On” display the values of all fields:
And it’s necessary to deselect all the fields and select just the desired one each time after applying the filter. For the “Hover Points On” tool, it’s even worse since there’s no option to remove the redundant outputs. I think that it would be much better to make the filters and tools display the values of only the current field (“Stress zz component” in this case) by default. Also when the current field is the one created for example with the Calculator filter (and named “Result”).
