help/about causes segmentation fault
currently, I’m running the latest 5.12.0 in client/server setup. After connecting the client to the server. if I click help/about to see details, it abruptly closes the session and in the server, it says segmentation fault.
client in Windows 11, server in Ubuntu 23.10
Screenshot 2024-02-26 092910
Screenshot 2024-02-26 092945
Are you using the official binary release on both sides ?
Yes, i have installed latest 5.12.0 in windows & in ubuntu server i used headless binary
5.12.0 is not out yet, are you using RC2 ?
There is an issue with osmesa currently, maybe it is this specific issue: https://gitlab.kitware.com/paraview/paraview/-/issues/22350
ahh! might be. I’ll use 5.11 then and check
Thanks
Alternatively, you can always try 5.12.0-RC3. Be sure to use this on both client and server.
I have seen this before when the server side Python is bad or mismatched. Everything runs fine until you do a Help/About (or Programmable filter or somesuch). Help/About loads the server side Python, which then crashes.
its happening in 5.12.0-RC3
Is there any log stored about the crash so that I can debug it
YOU create the log. You state you are remote server, I assume running pvserver in parallel. How do you launch the parallel job? If its qsub, there are arguments to write output and errors to files.
If I had do speculate on a possible cause of your problem, are you setting PYTHONPATH? This may be overriding the default in the Kitware build. Other than that, I have no idea…
@gpuligundla
Please check if this is the issue I linked above, related to glibc version.
Simple check to see if you are affected by this issue, just run:
/lib/x86_64-linux-gnu/libc.so.6
If it says anything above 2.35, you are most likely affected.
Best,
may be yes, i’m on 2.38
It’s happening in 5.11 too. What should I change?
How to use superbuild to build the paraview, I couldn’t find steps anywhere
Thanks
https://gitlab.kitware.com/paraview/paraview-superbuild/
This is not as trivial as using the EGL release that woks out of the box.
What all flags i need to pass if I need a headless Osmesa setup in my ubuntu without any errors while building
In https://gitlab.kitware.com/paraview/paraview-superbuild/ after cloning how to build, the steps are missing(I’m new to cmake)
