I am working with a horizontal colorbar. How can I rotate the numbers to run vertically instead of being displayed horizontally like they are currently? They are all smashed into each other. I want to be able to do something like this (copied from a different reference – I’m not sure what visualization software they use).
Or, if this is not supported, could you give me a pointer as to where in the source code I could find the relevant code that govern the layout of the text in the colorbar labels? I might try implementing this feature.
There is no option in ParaView to orient the text as you desire, but that is an interesting idea for a feature.
The code that generates the axis, including labels, is in VTK under VTK/Charts/Core/vtkAxis.h/.cxx. The color legend itself, which uses vtkAxis, is in ParaView under Remoting/Views/vtkContext2DScalarBarActor.cxx.
Thanks for this reference. Would you mind pointing me to the equivalent source file for the primary axis painters? It would help me resolve the other issue I posted: Remove Axis Tick Labels :
I see that the vtkAxis class supports independent booleans LabelsVisible and TicksVisible, although in vtkContext2DScalarBarActor.cxx the two are toggled together. This means that there is not a way to independently toggle the visibility of the tick marks and the numerical labels, which is precisely what I am trying to do in the other issue. I just need to locate the source for the primary axis configuration to implement this change.
